Can't shift to nuetral
msgtcujoman
I have a 1987 18' bayliner (3.0 OMC Cobra) I use to have to force it into nuetral, now it just won't go. And now it won't start, i think that's because it's to much strain in the starting system. Any clues?
Don S
Re: Can't shift to nuetral
Either your shift cable is stiff, or your shift interrupt system is inoperative. Or your idle is too high, or a combination of the three.<br />Can you shift it when the engine is not running?<br />The ESA (Electronic Shift Assist) is supposed to momentarily cause the engine to missfire to allow the dog clutch to release. <br /><br /> OMC Cobra Info
msgtcujoman
Thanks for the quick response! The shift cable is new. I can't get it in nuetral with engine off or running, even with a great deal of force.
rabidfish
You need someone the check your boat...<br /><br />You probably caused a small problem to get worse by continuing to run it.
Don S
Then something is together wrong. Stop forcing it, or you will have even more problems. <br />Take the drive back off, and inspect everything.<br />Check the link I gave you earlier, and make sure everything is right.<br />Have you been using a service manual?
KRS
Banned
My engine cover was sagging (plywood) and it was preventing the shift cable stud from moving, almost hit a dock.... scared the poo out of me. So check your engine cover for scratches, gouges... and remove it and try to shift.<br /><br />Hope this helps.
