capacitive discharge ignition problems
natedawghall
I'm blowing switch boxes and can't figure out why. What kind of abuses other than a bad ground to the switch box can cause switch box failures.<br /><br />Thanks,<br /><br />Nathan Hall
12Footer
Re: capacitive discharge ignition problems
Bad connections.<br /><br />Open circuit (plug wire pulled off durring operation.<br /><br />Internal pack PCB corrosion due to moisture getting into the pack thru a crack or someplace.<br /><br />Open or intermittant coil windings.<br /><br />that's abt all i can think of (been up all night,double shifts draw vacumm).<br /><br /> :eek:
Trent
Just to add to 12Footer's comments...<br /><br />Overcharging the battery will blow the packs.<br /><br />When an engine starts blowing power packs repeatedly, especially on the same cylinders, replace the ignition coils on those cylinders. The inductive kickback from a bad coil can destroy the packs, even if the coils check good with all known tests. A stator that test good can also be sending spike voltages to the packs causing them to fail repeatedly.
