Carb Adjustment
baxtr
1989 Force 125, fresh rebuild
Just looking for any tips to make sure I am not running too lean, very nervous about that. My manual says:
turn mixture screws until lightly seated
back screws out one full turn
with motor warmed up, set controls to high-idle neutral
turn mixture screws slowly counterclockwise, until motor loses power and begins to roll due to a over rich mix and note position
slowly turn screws closed, clockwise, until motor runs smoothly and begins to pick up speed. Continue turning clockwise until motor pops or stalls due to a lean mix. Note this position
set screws between the 2 noted positions.
Now, I did all that, but I am very nervous about running too lean, I noticed a thread response from Frank that said don't go more than 3/4 turn past seated. If I am starting at 1 full turn out, I am allready past 3/4. It was a lot of fun rebuilding this last year, but not something I want to make a annual project :)
nathan104
Re: Carb Adjustment
You turn the screw however much it takes to adjust it properly. I just did mine and my motor would not even idle at all until I was 1 1/2 turns out.
waquoitdave
Re: Carb Adjustment
I'm certainly not an outboard expert, but with any 2 stroke it is better to err on the rich side, at least until the motor has some time on it.
roscoe
Re: Carb Adjustment
From where you have it adjusted, turn it out 1/8 turn more.
If it is too rich, it will stumble stutter - then accelerate, when you give it throttle.
If it is too lean, it will die when you give it throttle.
Make sure you baby that thing during break in, and use double oil for 10 hours,
baxtr
Re: Carb Adjustment
Allready ran double oil through, broke it in, runs great, just wanted to be sure about the carb adjustments. I am pretty sure I got it right, and I did even go a bit richer just to be sure, was just getting some more opinions on how to know for sure.
Thanks
