carb and cylinder spitting gas
danhaiz
1995 evinrude oceanpro 200 spitting gas (Backfiring, stalling) in one cylinder. Changed reed valves, all gaskets, got spark, changed power pack, plugs wires, rebuilt carbs, adjusted needle, did it all I think? You can see a build-up of gas at the bottom of the barrel on the carb. No others do this. Exc :confused: hanged carbs and does the same only on that cylinder, Had a marine motor mechanic take apart and look and put it back together with new gaskets and does the same. Thanks for replies in advance.
JB
Re: carb and cylinder spitting gas
Hi, Dan.<br /><br />Welcome to the board.<br /><br />Please do not double post, and please post in the correct forum. You can get some excellent advice if you click on the "Suggestions for New Posters" link at the top of the page.<br /><br />I am moving this to the Outboard Forum.
