Carb and idle
viper1
Trying to idle this merc cruiser. Seems it should have a spring on the return. Adjusted the linkage and cant seem to get a happy medium. Idles to fast. push the carb linkage down and it is fine. Rev it or give it gas and try to return to idle and it gets to high. Seems like the linkage or something is sticking in carb. Only takes a small amount of pressure and its fine. Other wise it runs smooth. Any Ideas?
viper1
Well I did. Either didnt do it right or something is changing. This time I put some load on it. Will see how that works tomorrow.
Ayuh,.... The cable has to be Pushin' against the idle screw,....
Not Alot, but Pushin',.....
