I'm having a pain of a time trying to locate adequate carb studs locally to attach my "new" 4bbl to the new intake. Is there any reason I can't use bolts if they will clear enough to get them in the holes? The only problem I see is that one bolt is partially obstructed by the secondary fuel bowl (Holley 4160), but If i file off about 1/32 of the head on one flat, it will clear. I would use a Hex bolt, a flat washer, and a lock washer. Already checked and the bolts are the perfect thread pattern... So...Bolts ok to use instead?<br /><br />Also, as I remember, carb base gaskets are installed without any sealer. Can someone confirm?
