Re: Carb cleaner spray....?
Thanks everyone for your thoughts,,,<br /><br />Here is what I think.... I believe there at least is an advantage to using both the gas additives and the carb throat cleaners, but how much do you gain from them is obviously up for debate... <br /><br />IF,IF,IF, You were getting ready to winterize your boat, using fuel stabilizer, fogging oil, the whole shabang,,,,,, Is there an advantage to using a decarb spray first, the type that you spray in a running engine like they instruct on the can... Or is it better to eliminate that whole process?
