Preparing to clean/ re-gasket my 3 WMV 18 carbs. I've cleaned many cycle/ car carbs, but for some reason feel a little more tentative with the outboard. I've read all the carb threads, but still have a few questions in my mind.
First: The Idle air jet, backdraft air jet and main jet. I assume you would remove them during cleaning? or not? I dont believe there is any type of oring....perhaps they are sealed in?....Service manual is silent on the issue.
Second: Idle misture screw. Now this guy I know I have to take out to clean well. I'm planning to turn in to seat measure turns, BUT, have to admit, I have reservations about having to tweek 6 separate mixture screws after the rebuild. If I get the screws back "very close" to where they were, should be in the ballpark, eh? Anyone recommend going back to manufacturer setting (1 1/4 turns)?
One last thing: Planning to replace inlet needle/seats(at float). But other than those, gaskets, float check and a good cleaning, I cant see anything else necessary unless it is obvious when I open it up. Any other suggestions?
