carb cleaning
parryboy
OK...just removed the carb and dismanteled it. I cannot find a place local to me that sales carb cleaning solution.... is there anything I can use instead?.....
parryboy
Re: carb cleaning
thanks but need to get job done today and the problem is there isnt anyone near to me who has carb cleaner....I was hoping that I could use something else... petrol, solvent....any other suggestions?<br /><br />Thanks!
parryboy
Re: carb cleaning
also I should add that the carb is quite clean...I had it cleaned three weeks ago but I made the stupid mistake of running the engine on really old petrol since then....
gss036
Re: carb cleaning
If were just cleaned 3 weeks ago, blow out the passages with air and run it. Your only concern would be open jets, passages,etc. Check your filters.
rabidfish
Re: carb cleaning
Yep, blow them all out... you shouldn't have any real build-up yet.
LubeDude
Re: carb cleaning
I clean nearly everything in my shop with laquer thinner and acetone. Great carb cleaner. Just dont get it on plastic parts. But as stated, you probably just need to blow everything out good. If you dont have access to compressed air, those air cans that you clean computers with will do.
parryboy
Re: carb cleaning
Thanks for advice.... have done as suggested...and it works fine....GREAT!
deaconn
Re: carb cleaning
do i have to take the carb off to apply carb cleaner or can i just spray away.
Af4408
Re: carb cleaning
Don't spray carb cleaner in the carb throat, it goes directly into the intake and in the cylinders and can wash away your lubricant. What I've done to clean the carbs of old sludge is: Mix 1 pint of laquer thinner in six gallons of gas/oil mix and run your outboard until you've used up your fuel. The thinner will go in the bowl, orifices and jets disolving the sludge.
