I recently inherited a 1971 6 HP, I took it home and hooked it to a gas can and it cranked on the first pull. However, the plastic housing that the filter screen is located in had a crack in it and it was leaking gas. I ordered a new one and a new screen and installed them. While the motor was sitting up waiting for the new parts to come in the float apparently stuck as gas would squirt out of the carb while I was squeezing the bulb. My neighbor took it home and took the carb off and cleaned. Now it will not start. The carb is getting gas because we took the drain plug out of the carb and gas ran out of it. It will start if you spray gas in the carb but it only runs until it burns the gas that I squirted in the carb (about 5 seconds). The motor had been sitting up for about 10 years but like I mentioned before it started on the first pull when I first got it home. Any ideas because me and my neighbor are about to go crazy. Nothing was replaced in the carb because he said it all looked fine once he got it cleaned up. He did say that the little gasket that goes on the idle adjustment was rotted and fell out but no gas is leaking out around the idle adjustment. How many turns out does the idle adjustment need? Any thoughts on what the problem could be would be greatly appreciated.
Thanks
Thanks
