maineiac5586
- Feb 14, 2009
- 790
ok, my 76 500 is killing me. i pulled the carb because i had a bog when accelerating. adjusting the idle mixture screws made no difference to performance. after pulling carbs i found restriction in passage for idle mixture screw. cleared restriction and checked rest of carb, all checked out ok. reassembled carbs and installed on engine. fired it up tonight on the muffs and started with idle mixture scres out 1 and 1/2 turns from lightly seated as per manual. starts fine every time, bog is horrible to the point it stalls engine when acclerating. played with idle mixture screws and can get a change in the way engine is running when adjusting but bog doesn't change. just for a test i backed the idle mixture screws almost all the way out and was able to remove most of the bog but this doesn't seem right. any idea??????? i should note engine reved cleanly on the muffs before removing restriction from idle mixture passageway.
