Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
i have a 1969 55hp johnson haveing carb problems i have a set of fixed carbs off a 70 johnson the i think will bolt up can any one tell me if this will work thanks
They will bolt up although you may have to do a little jetting. The newer ones don't have choke plates so you could upgrade to the injection primer.<br /><br />Good luck!
