The last mechanic that worked on my engine adjusted the idle way to rich (blue smoke) and now I am having starting problems. As you face the carbs which screws are the low speed idle adjustments?<br />I believe there are two screws per carb. I have been told that the high speed adjustments are factory set and do not need to be adjusted. Is this correct? Thanks
