Re: Carb jets metering air?
Hi and welcome Jan-Egil.<br /><br />I know that the manual indicates that the port and starboard carbs have different low/medium jet settings (the two jets you are referring to), however, I don't believe the upper and lower carbs should have different jets settings (I'm at "on the road" for a few days so I can't confirm this in the manual at the moment, just going by memory). In other words, I believe that both upper and lower carbs on each side should have the same jetting (remember that I'm just guessing based on memory).<br /><br />As for the appropriate jets, all the numbers you referenced seem familiar (16,20,24) so I think your problem may just be a matter of rearranging the jets between your carbs. As for the altitude issue, sorry can't help you there. Maybe start a new post with that question.<br /><br />If you haven't got a manual, I'd go get one. It will advise on the appropriate jet placement as well as solve any number of other problems you may encounter.<br /><br />If you're still encountering problems, I'd start a new topic on the forum as your questions might not get the attention they deserve at the bottom of my post.<br /><br />Good luck and keep us updated.<br /><br />Cheers.
