93bayliner1800
- May 9, 2011
- 239
I have a 1989 Mercury 2.4 block with vertical 5 pedal reeds front half. I have WH-33 carbs and I live below 2500ft. This is mounted on a 1993 18ft Bayliner. I run a 3 blade 19 pitch prop. I am all about holeshot for watersports and rarely go over 5000rpms. I am currently running .64 main jets and .54 idle air bleeds. I thought this was a 2.0L 150. I am currently re-building this motor and disovered it was a 2.4L. I assume that makes this a 175hp instead? I know from looking at this motor during the rebuild it was running a little lean, but still loads up bad on very short idle time. The carbs were re-built by the mechanic 2 months ago before he installed the motor on this boat. I have all new eletronics. I also found a vacuum line broken during rebuild behind power pack going to #5 cylinder. I am just wanting to make sure I get it right before putting this new motor back in water. Thanks for all your help, Tim
