kenimpzoom
- Jul 13, 2002
- 4,807
Does this sound like an ignition problem or carb problem?
93 Mercury Sport Jet 90 ( 3 cylinder inline, Force powerhead, three carbs)
Engine runs fine at idle, but low on power. I can ground the bottom cylinder spark plug and it makes no difference in the power, so it is definitely the bottom cylinder.
When running around at ? throttle, it will occasionally pick up speed and run correctly with full power, it only last a few seconds, then back to low power.
I have verified it has spark at idle on all three cylinders.
I am leaning towards an ignition problem (weak coil, shorted wire, powerpack failing, etc), but do you think it is possibly a carb problem? I would think if it were the carb, it would run badly all the time and never occasionally run right.
I am leaning towards swapping around the coils to see if the problem follows the coil, and also using the timing light to confirm spark while at speed.
Thanks, Ken
Thanks, Ken
