Colroado Boater
- Nov 22, 2008
- 6
Hello all
I am having a issue with my 1984 50HP Evinrude. It want to fall on it face per say when you try to do a hole shot from idle. Here is what i have done so far. I took both carbs off and completely took apart and soaked over night in sea foam and carb cleaner. Took air compressor and blew out the carbs. Put the carbs back together. Went to the lake started off fine ran great. After about 30 min, shut it off fishe for a while. Started it back up let motor warm up. Opened to WOT and boat stumbled and died. Re started the motor. slowly went to WOT ran great. Does anyone have a clue to what and why this is happening. The only thing i havent done is bought all new parts for the carbs. thats the next step i see if i can't fix it another way. really dont want to spend 100 dollars and it not fix the issue. Any help would be great
Thanks
Thanks
