Carb problem 25hp
yeoman1
The float needle in my Mariner 25 continues to stick closed, after a thorough cleaning and rebuilding of the carb with replacement of the needle with a new one. I can put it on, run around the river, idle, run home, all's well. Go to start it a day later, won't start. Pull the carb, drop the bowl, the needle's stuck. Use finger nails to pull the needle, put it back, reassemble, off we go. I've done this no less than 10 times. This is a 1987 engine. I can't believe they designed a carb without a replaceable seat for the needle, AND without a wire clip from the needle to the float hinge mechanism. Anyone ever run into this problem?
yeoman1
Re: Carb problem 25hp
This engine bears the serial number sticker but the white strip is blank. We've only narrowed down the year by part searches. The carb is the 1984-1987 for example. Why do you ask?
ehenry
Does the carburator have a needle seat that needs to be replaced? Just curious.
ehenry
