deputydawg
- Aug 29, 2004
- 1,607
I am posting for a friend that is getting his boat ready for spring. He has a merc inline 6, I think about a 145hp. It is a 1974 model with a rochester 2bbl carb. Engine was running rough so at my suggestion he changed cap, rotor, plugs, wires, coil the works. All with new marine parts. Replaced all fuel filters and flushed the tank. <br />Engine will not idle, and is only running on the front 3 cylinders. The back 3 are getting good spark, good compression, removed and replaced head and all is good. But remove plug wires from the back 3 cylinders and the idle won't change. Can't be cap and rotor, these 3 don't fire one after the other plus these parts are new.<br />My question is this.....is this a dual plane type intake? The carb had some junk in it plugging some passages. Will rebuild it or replace it when he gets money. I turn the front idle mixture screw in and the idle changes. I turn the rear set screw in and out all the way and idle won't change. The way the 2bbl sits on the intake, I was wondering if the front venturi fuels the front 3 cylinders, the rear fuels the rear 3 in a dual plane type setup, or if this carb problem could be causing this miss because of the location of everything.
