I'm going to tackle rebuilding the carb on my aq125A. I ordered a rebuild kit and yesterday I tore down the carb to inspect it. From the looks of it, it has either never been rebuilt or it was rebuilt when you could still get volvo parts (or NOS parts were used).
Anyway, I am rebuilding it because the engine idles fine in and out of the water. Will smoothly rev up in neutral, but when I am in gear and under load if I slowly try to increase speed the engine will start to bog down and die once I hit 1500-2000 rpms. I can almost always stop the engine from dying if I pull back on the throttle. If I am very careful I can get the boat to slowly increase speed, but usually it is easier to just punch it and go straight past the 2000RPM mark. Once I get underway and past 2000 RPM the engine performs great. WOT is around 4500-4800 RPMs and it is very strong. Once at plane I can back off to around 2500-3500RPM.
So, anything I should pay particular attention to when cleaning the carb parts?
Any recommended cleaner?
Should I soak any of the parts first? Especailly the small tubes where it is going to be very hard getting cleaner into them?
It looks like the starting place of the idle screw is 1.5-2 turns out. Any other default adjustments I should make?
Finally, there is a black rubber hose running from the engine to the flame sheild. It doesn't really clip in securely. Should I be concerned?
Thanks
Thanks
