Carb rebuild
Tail_Gunner
Recently i decarboned a 13 yr old 3.0 merc (water) Actullayed smoothed out the idle a bit and ran quite good, But after setting for a few day's the low speed circut is now plugged quite well. Tried to remove the low speed needle and flush it but that did notta, so i am left with either a rebuild for maybe 50 or a rebuilt for 200 with core exchange. What concern's me is the amount of debrie's i must of picked up during the decarb and can it be blown out just using a air nozzel or should i just do a rebuild. Any opinions here.... its been years since ive done them but when i was it was pretty simple enough.
ziggy
Re: Carb rebuild
i'd go for the rebuild. i'm a cheap azz. if ya loose, well, lesson learned. i don't think yer gonna do anything cleanin wize from the outside. only time i'd go to R&Rin is when parts are worn and don't interact proper. ie. throttle plates on a worn shaft, shearin away the venturi so ya get no idle circut. irreputable. plugged ilde circut would do it too. but i'd think tryin would be in order. i'd think soak it in a tank, + air and ya may have a chance.........
Recently i decarboned a 13 yr old 3.0 merc Recently i decarboned a 13 yr old 3.0 merc (water)
how did ya do that? and what's
, sorry i aint understandin that.......unless ya ment decarbed by water injection, mist.......
Boomyal
Re: Carb rebuild
Gettin' a little nervous, huh? No stinking rebuild is gonna save your hide. (and if you had any cajones, yer pink slip too):p
Tail_Gunner
Re: Carb rebuild
:D Yup very slowly poured about a 1/2-3/4 cup of water in her at about 1200 rpm, let here run for about 10 minutes 3 days later she's (idle circut) plugged hard. The carb has no wear on any of the linkage's choke is solid never a problem in 13 years, but the preivous owner just putted around i doubt the boat has even seen Wot...:D
Boomyal
Re: Carb rebuild
^ bump
You was talkin while I was jawin!
Tail_Gunner
Re: Carb rebuild
:D Naw this one's from the starcraft, it's time i finsih that old girl out Gunner's wife doesnt like seeing two boat's in recon at one time......think's i'm playing to much...... Oh by the way iv'e found a prop for that old barge of your's
Speed prop your going to need that............... Jeeshhh maybe i just out to take the old Star Craft out and save you some dignity......:cool:
Reel Poor
Re: Carb rebuild
Don't worry TG, I'm thinkin Booms carb is still in the box. :D
Tail_Gunner
Re: Carb rebuild
Ok be nice, now if you were that damm ugly of a carb........ wouldnt you be hidin in a box...........:D
Umm Boom you think that prop migh have to much cupping for that old scow...
Tail_Gunner
Re: Carb rebuild
ok back on topic, i can see no vacum lines that could have did this, making it fuel (alcohol issue and i do have 3 inline filter's) am i missing somehting here?
