This outboard is leaking fuel out of the screen on righthand (starboard) side of carburetor when the Primer Bulb is pumped (and even a bit while running). I strongly suspect a stuck Carb Float.
What is the easiest way to remove the Carb? Do I need to remove the Breather Box and the Top Cover? If so, are there any cautions/"Gotchas" I should look out for?
The mechanical configuration on this E8RECR is very different than the 1986 or prior 9.9hp/6hp/4hp I have worked on. quite a bit. So any inputs would be appreciated .
