Blind__Squirrel
- Jun 14, 2019
- 4
Greetings Everyone,
I have searched and found many answers on this forum but this is my first post.
Boat Info
Boat is a 2002 Tracker Targa 18 I/O 3.0 MerCruiser Alpha 1
I have just finished rebuilding the Carb.(Kit came with thin base gasket and I have read that can be a problem adjusting the carb,)
New fuel filter in carb and added an in line fuel filter between tank and pump. ( Boat sat for 2-3 years and tank was really bad. I flushed it as best I could by putting fuel in it and pressurizing the tank to push fuel out by extending the hose to the pump out of the drain and catching it multiple times. Would have to remove the floor and consoles to free the tank in this model boat. Had to cut a hole in the floor to replace the sending unit in tank)
New marine plugs, wires, cap and rotor are arriving in the next few days for a complete tune up.
I believe timing is good and will reaffirm after the tuneup.
Factory tach only.
The boat runs OK with just the carb rebuild but does not like to idle in the specified range. Adjusting the carb has not helped and i cannot get it to stumble when adjusting.
I am not going to assume that the rest of the tune up will fully resolve the issue given what I have read about the base gasket but should at least make an improvement.
My question is will a carb spacer assist in improving idle?
Sorry for the post length, wanted to include applicable info.
Has anyone had any experience with the spacer assisting with idle, warm starts or general performance at/around idle?
I do not expect to see performance gains, as i understand it the 3.0LX is what it is and that is fine.
I am purely interested to know if a spacer will assist in obtaining a smooth idle. The thicker base gasket is said to make a difference We do idle a lot as we net for bait and when we run jugs to catch smaller cats for the freezer. In doing so we shift the boat in and out of gear often so I would like my idle at the lowest end of the idle range as possible. We also move frequently when fishing and have noticed a little harder start when warm.
Boat Info
Factory tach only.
