KRH1326
- Sep 22, 2007
- 491
Hi Everyone,
Now that I have my Major problems worked out for now, I can work on some of the Minor ones.
I idle out of harbor at or under 1000 rpm, because of no wake zone. Once I hit the bay, I can throttle up. As the RPM's come up, mostly at about 1500 to 2000 rpm under load, trying to get speed up for plane, the engine kind of bogs. At that point it will either stall, or if I goose or bump it a little, it will overcome the bogging and continue on, climbing rpm's.
All of the ignition parts are new as, this is the first season on the water with this project. It has a new fuel pump and a new fuel filter and seperator with a gauge hard piped in the discharge, and am getting steady fuel delivery. The engine is tuned real well. Plugs, point gap & dwell, timing setting, even checked with advance curve. Beautiful idle @ 500 rpm. All seems well.
The carb is a Holley 4 bbl. List 7163. It was rebuilt by Lyle Stahle , at Stahle Performance Carburetors, Inc. a reputable carb shop. It basically is :
600 CFM Holley Vacuum Secondary Carb List #7163. Original equipment on a Ford Marine 351 engine, this carb would be well suited for 350-400 ci applications. This carb has been rebuilt with a genuine Holley Kit and is ready to bolt on and go.
Standard Features:
? #65 Primary Jets
? #25 Power Valve
? #25 Primary Pump Shooter
? 30 cc Primary Pump
? New .097? Viton Needle & Seat
? New Vacuum Secondary Diaphragm
? Power Valve Blowout Protection
? Electric Choke Standard
? "J" Style Vent Tubes
? Universal Marine Throttle Lever
I am usually alone in the boat so it is difficult to see exactly what is happening, but recently, I took the old man out, and tried to snoop around while he was driving.
I am not a carb guy. I never ?got it? and never will. Not that I know what I am looking for, but the carb seemed to be doing its thing. If he increased throttle, it got a little shot of gas, but I did notice that when it was trying to bog down, if I assisted the secondary bttfly, it immediately took off like nothing was wrong.
I have the OMC Select-Trim, which actually raises and lowers the front of the engine. I have been researching and it may be possible that if the engine is tilted aft, and natural g-forces could affect the bowls? I have not noted what position the engine was in as this happens, that will be my next mission.
Could you please give me a direction to look in, that may help?
Standard Features:
? #65 Primary Jets
? #25 Power Valve
