Carb to intake gaskets???
roger46982
The gaskets between my carbs and the intake are smaller than the opening in the intake manifold will this cause a problem?
iwombat
Re: Carb to intake gaskets???
They could. Those gaskets are also largely un-necessary. If the carbs don't make a tight seal to the airbox you leak . . .
wait for it . . .
air.
roger46982
So you are saying it matters not if the carb gaskets leak?
Gibbles
as long as its not the gasket between the engine and carbs
