carb?????
BOBBING
HI THERE I HAVE A 1996? EVINRUDE 15HP PULL START .WHEN I START IT , IT IMMEDIATELY STARTS AND RUNS AT QUITE HIGH REVS I CAN SPEED UP BUT NOT SLOW BACK DOWN BELOW HIGH START REVS I THINK IT IS RUNNING ON HIGH SPEED JET ONLY ANY IDEAS ROBI
Look over the motor for loose linkages.---Did this happen all of a sudden ?----How long have you owned this motor ?---To me it sounds like timing is too far advanced.
kbait
There's a safety feature that locks the recoil if your throttle setting is too high when you try to start. Does your motor has a red plastic recoil blocking arm, visible near top/rear of recoil? If it does, and is broken or incorrectly installed, it can prevent the armature plate from pivoting to idle position. If that's it, you'll see what I mean when you pivot that plastic piece and turn throttle down.
Good luck!
kbait----Note the poster is asking about a 1996 model here.---Not asking about a 1992 model and earlier !
flyingscott
If you have a tiller check the throttle lock on the end of it. Knob that sticks out of the tiller handle loosen it.
BOBBING
HI MOTOR IS ON REMOTES AND ALREADY CHECKED LINKAGES AND I DID LESSEN REVS A BIT BUT STILL RUNNING FAST
BOBBING
HI K BAIT I WILL HAVE A CLOSE LOOK AND SEE IF I CAN LOCATE THE RED TAB HOPEFULLY THATS THE PROBLEM THANKS ROB
flyingscott
You do not have the the red safety. Does the throttle cable pull the linkage all the way back.
oldboat1
Remove the remote cables, and operate the motor manually -- need to determine if it's a an issue at the motor or an issue with the remote, and adjust accordingly. Assuming the motor is adjusted and running properly, would adjust/reattach the remote cables to match motor settings.
jbcurt00
Bobbing
Turn off the all caps. It makes it hard to read and seems like you're shouting.
oldboat1
If the motor is not idling down properly with the remote cables removed, you know the problem is at the motor (sometimes disguised by issues with the remote).
You want to be sure the throttle linkage allows you to fully close the throttle, that operating the grip or manually operating the throttle cam gives you full range opening and closing. You should post a model number, as there are a number of models -- The model number will also indicate what year it is (some question in your initial post).
