carberator rebuild question
john1947
hi, im installing a carb on a 120 evinrude. It has a o ring on the body that keeps falling out.any ideas.
thanks
Daviet
Re: carberator rebuild question
Put a little grease in the grove and push the oring into it, that should hold it in place so you can install the carb.
colding
I'm having trouble keeping my seal in place during reinstallation as well. Can I use any kind of grease? This won't hurt anything if it gets injested through the carb?
Chris1956
The grease would not normally be sucked into the carb, due to it's density. If it gets cut by gas or if a bit does get sucked in, the fuel passing around it will cut it down and it will get burned up w/o issue. of course, if a clump gets sucked in it, could clog up something. Use it sparingly.
colding
Thanks! I'll give that a shot tonight.
