BornBlue82
- Feb 11, 2013
- 59
Ok so being new to the boating world, I decided to go through my engine yesterday. Just to get familiar with everything. I noticed that the spark arrester was all caked up, so I decided to clean. When the carburetor was rigged up and I thought that's the way it was supposed to be, until I got a closer look. I have a metal band that goes across the top plate that is zip tied on each side. Once I removed the cover I soon found out why. The bolt that holds the flame arrester and cover doesn't connect to the carb, the piece is no longer there. which is why the metal strap is holding everything in place. Also there is wire loom instead of hose going to the flame arrester, is this normal or do I need to replace that with rubber hose? The carburetor part number is SAE J1223, is there a way to just get parts for that? Is there a place that has used ones? What is my best option? I've posted pictures below to show the problems. Any advice would be greatly appreciated.
P.S. The boat runs great with no problems, this was just a find during exploration.
