Hi! Just put new carb kits on both carbs of my Johnson 100. (J100STLCEM). Set the floats IAW the factory serv. mnl. After reassy. I did the blow trick, with the carb inverted. They seem to seal pretty well ,but will still bypass some air.(The old needle & seat seem to seal better). After putting them back on, when I pump up the primer bulb,if I pump until the bulb is hard, fuel comes running out of both. Question is, should this happen if they are primed too much and if so how to tell how much to pump the primer to avoid this. I feel that the float and needle should seat, however maybe the bulb has enough force, if pumped enough, to force in fuel.
