carburator fuel line
jorgeoliva
I just rebuild my 2 barrel card on a 2000 5.0 mercruicer inserting the rigid line in the card is a pisser so I cut the rigid line and inserted a 3/8 fuel line with hose clamps but now the engine starts but the only way it stays on is if I throttle it. so question is this invention I did not giving me enough fuel in the card. do they sell a complete rubber hose from the filter to the card. any help will be appreciated
you probably have an air and fuel leak.
the steel line is a requirement, however you can also use USCG type A1 fuel line. if you have any old 3/8" fuel line, that is a bomb, and in violation of marine fuel system requirements.
No they do not sell rubber hose from the fuel filter to the carburetor. it would be about 5 x the cost of the steel line.
Grub54891
I'd say the issue with it not running, is a issue with the rebuild. The rubber line should be allowing plenty of fuel, unless the fuel pump is shot. Now on the other hand, the fuel line should be hardlined from the pump to carb. You should not use the rubber line in that location, and if you use it in any other approved place, it has to be marine rated uscg approved.
Bt Doctur
Get some steel brake line , a double flare kit and make the correct size steel fuel line.
Feel sorry for you if that happened during whooopie
jorgeoliva
I just found this one do you think it might work in replacing the steel line it says it replace the original steel line
jorgeoliva
this is the other part of the description. For fuel pump to carburetor connection. Replaces copper or steel tubing 3/8" X 25" PTFE composite hose with 5/8"-18 male inverted flare straight one end, 5/8"-18 90? one end.
SAE J1527 type A1
Grub54891
Agreed, A1 is fine, I did not know there were replacements like that.
flipbro
Master Chief Petty Officer
I did as Bt Doc says bent my own worked great and inexpensive if you've got the tools already.. What's the price of the fuel line you posted the link too?
Ayuh,.... No doubt a blocked iboats competitor,....
Bt Doctur
176464-sierra-sie-18-8115-it1
Ayuh,.... It's pretty cool, but I can bend one up outa 3/8" brake tubin' for under 10 bucks,...
Fishermark
Yep. You don't even have to cut the line and get a double flare kit. Just buy a steel line pretty close to the length you need and bend it up. Like I did here:
