carburator problem? 25 HP mariner
cecrouser
Motor has set up for awhile. I removed the carb and cleaned it before setting it up. Motor will start, but dies right away. If I keep hitting the choke it will keep running. I have removed the carb three times and cleaned it. Still does the same thing. Motor is a Mariner 25E SS# 695 S 25295
AMD Rules
Re: carburator problem? 25 HP mariner
Bad fuel pump?<br /><br />Will it continue to run if you manually squeeze the bulb in the line?
cecrouser
No, I tryied that and I took the hose loose,turned the key and gas came from the out let. Changed out the line and bulb between the trank and motor too.
andy6374
Maybe your carbs need more than a cleaning, perhaps you have a stuck needle. Bad Floats...<br /><br />-andy
Yepblaze
You probably need to further dis-assemble the carb before calling it clean. Or gently probe and spray the orifices for hardened deposits.
