Need Help,<br /><br />I had a friend try to rebuild my carburetor on my 4.3 V-6. It runs fine except it will not get above 3800 RPM. <br /><br />He said he replace the needle valve with the one in the kit. The old one had slits in it, where the new one does not. Could this be the problem? or Could it be that the float needs adjusting to let more fuel? He left that alone and it is just like it was.<br /><br />My original problem was that it would run fine then start to die and then die. It would start right back up and the process would start all over again. I clean the fuel screen in the tank before the carburetor was put back on. Anyway that problem is solved, I just do not have any power. Any suggestions?<br /><br />Thanks<br />Greg
