Carburetion/Grease
gibbywmu
Does anyone have any suggestions for KEEPING the carburetion/grease stains off the transom of my boat? Ive got a 1997 Powerquest w/ Carbureted 454 Mag..........Get a TON of grease/carburetion build up after each use. Always have to wash the back with 409, Simple Green, or soap to get it off. How do I keep it off in the first place? Obviously comes out the thru hull exhaust ports.........Thanks!
Re: Carburetion/Grease
Your engine is running Rich,.............<br /><br />Fix It,+ Most of the soot will Go Away.......... ;)
gibbywmu
Ok...so just adjust the carburetor to make it not run so rich?
waterone1@aol.com
Either your engine is running rich, or it is burning oil. Pull the spark plugs and "read" them. You may need a carb rebuild, or an engine rebuild.
