carburetor adjustment 197140 hp evinrude big twin m/n 40153
a2012fatboy
hi everyone i just wanted to see if anyone knew where i should have low speed lean at and high speed lean it wont go as fast as it should any help greatly appreciated also which way should i be going with on both of them leaner or richer? i'm using 50:1 ratio i hope my problem makes sense to someone thanks
F_R
Make life simple. Think of those things as faucets. Turning it to the left opens it (more fuel flow--richer), turning it to the right shuts down the fuel flow (less fuel--leaner)
The goal is to set them as lean as you can without losing power. If it starts to lose power from being too lean, turn it back to the left enough to regain full power. You can hear it. If too lean on slow speed, it usually will sneeze & quit.
Beginning point: 1/1/2 turns on slow speed, 3/4 turn on HS.
a2012fatboy
ok obviously i should have my gear in neutral should i have my throttle all the way down or wot for slow speed to have it sit idle and for high speed can i have it on ear muffs to adjust it or do i need that on the water to make the correct adjustments?
Boat must be in the water and in gear.---First adjust high speed ( bottom needle ) at full throttle.-------Then idle the motor down and adjust the low speed needle.
F_R
Agreed, it is impossible to adjust the high speed on muffs. It must be on a boat, on the lake, in gear, wide open throttle. Um.....you will obviously need a driver at the controls while you are back there messing with it. Be safe, that thing will go fast enough to kill.
a2012fatboy
ok so both slow and high need to be adjusted in gear and go from high to slow got it, now when i'm adjusting the slow one do i get it to the point where the throttle is all the way down without having it die on me? sorry this is my first boat and no marine mechanic will touch my motor
a2012fatboy
oh also do i need to take out the knobs for the levers? and adjust it without the knobs?
a2012fatboy
