Re: carburetor question
The AQ271C's were Holleys, but not double pumpers.
Do u still have the one that was on there? and any chance of Pics?
The carb would have been painted red from VP.
Double pumper and Vac secondary Holleys adjust the fuel level the same way with the sight plugs.
Now, what do you mean by "shoot quite a bit of gas". The fuel bowl level has little to do with how much the accelerator pump squirts out. If there is enough fuel in the bowl the pump will shoot the same amount as if it was overfull. The accelerator pump diaphragm housing determines the volume and the squirters determine the duration of the shot.
I think a double pumper is too much for that engine. The original carb had quick opening secondaries due to the vacuum diaphragm spring the spec calls for. Also the power valve in the primaries is a 2.5hg so it will open sooner under load, and the jets are staggered (not the same size side to side) and larger than "stock". The secondary metering plate does not have jets or a powervalve even though there is a metering block. I can't remember the size of the squirters called out, probably 30's or 31's but the accelerator pump diaphragm housing is the smaller 30cc and not the 50cc that is usually found on double pumpers.
