Carburetor rebuilder service
Trader Vick
Anyone know of any carburetor rebuild rebuilder services that work on mercury outboard carburetors? Have a 2001 Mercury 50 hp ELP with 4 cyl and 4 carbs. Internet searches have only come up with places that do inboard engine carbs. One place said they could, but, have no way to test, so they wouldn't.
Faztbullet
You can rebuild them but the secrect is sync and linking them and balancing...
If you hire this work out it will be big $$-------Then you need to have them balanced with vacuum gauge once installed.-----Are you sure the carburetors are the problem ?----What is the motor doing / not doing ?
Trader Vick
I have the 4 vacuuum guage carb sync kit, for when the carb is ready. right now the engine has new plugs, fresh gas, strong equal compression in all 4 cyl., the timing is all electronic. it is off the boat, on a stand, for repair. I bogs when I try and accellerate. rough idle. If i spray starting fluid in air intake it revs up nicely and I can accelerate it to high rpms and it is smooth and keeps running. carbs seem only ting left.
