Re: Carburetor Tuning
I just got off the water a few hours ago... I rebuilt the carb and adjusted everything. I replaced the ignition cap, rotor and checked the timing, which was perfect. The engine idles perfectly now and runs smoothly until I try to go full throttle. Basically the exact same symptoms as before the rebuild. I also replaced all filters and cleaned the fuel pump. I am able to get to about 2900 rpm and anything more than that and the engine starts stumbling. The more throttle I give, the worse the stumbling and basically the engine just slows down. Once I back off the throttle to about 1/2 to 3/4 it goes again. When I creep the throttle up just to the point where it starts choking, if I back off the throttle a hair, it actually gains 50 rpm or so after it drops. What's the issue here? Is this due to main jets that are too small? Is this fuel starvation? This is a Rochester 2bbl off a 2.5 liter and put on a 3.0 liter. If it is main jets, which I think it is, where can I get bigger ones, and what size should I get for a 3.0liter. When I rebuilt the carb, there were no numbers on the jets to describe the size. I am familiar with working on Mikuni carbs for snowmobiles and jetting, but this is a little different now. Thanks.
