Hi guys, I have a chance to buy a late 80's/early 90's 31' Carver that sank in 6' of water. It's been there in the lake since January, the fibreglas top (fly bridge or ???) is off on one side from wave action. It's tied to a tree on shore and anchored at the stern so it's not going anywhere. It's actually still floating, bobbing in the waves. Supposed to have (had) a good running 350 Merc. First issue is getting it floated, then do I restore, or scrap it after getting the engine/leg out.
So several questions..I have a nice 5HP 2" trash pump that will get it pumped once level and gunwales above water. I was thinking to just drag the stern close to shore, and if need be several big truck tire tubes to level it and refloat, then pump out and get her floating and tow to ramp with my 21' Sunrunner. I have scuba gear but may not need it as it's right at shore and not deep. A young lad swam thru it with snorkel/mask last week to check it out and no hull damage. It was just a winter storm and got swamped and no bilge pump, or dead battery and sank. The owner (who I know) just left it there..who knows why.
So, for $500 I can have it...will the engine be toast or can it be drained/flushed and salvaged? I assume the leg will be fine, or at most drain and fill. As for the hull, everything wood will be saturated and will need eons to dry out, if ever.
What should I do? I could use the engine/leg for my 20' Sunrunner, which is ready to go except it needs the engine/leg. If the whole boat is salvageable, then I might restore and sell.
Your thoughts?
Cheers
Your thoughts?
Cheers
