Re: Cat 3208T - Oil Bypass Filter Install
Its a great idea to use a by-pass filter, you can extend your oil change interval greatly. Im not familiar with this engine, but you can T into your oil preasure guage line for the inlet, and if your engine has a turbo, you can go back in where the turbo return line is, provided it is not presurize, most are not and are just a drain. Otherwise you may have to tap into your oil pan.
