catfishcarl99
- Apr 25, 2012
- 723
Well the old CATillac (17' spectrum us marine fish and ski) i got back in 2004 needed a floor. the rear was falling through and getting real soft. So a couple weeks ago i decided i would just get it done. we went out fishing while back and i about went through it so i got busy.
it was a job but really wasnt as bad as i thought. i thought i was gonna have to remove the side panel beams that was running through the rear to front and the drivers consoles. i did not. the old floor only went under the lips about 1 1/2".
the foam was soaked with water as i found a little hole in the bottom from a rock. it was small but about the size of a flathead screwdriver tip. so i removed the foam and put new in. i used 5/8" treated plywood. i used rubber strips over the aluminum that the floor went down to. as the new ACQ treated eats bare aluminum up. chemical reaction from the chemicals or copper in them. also i painted 2 coats of exterior paint over the wood to keep water out. cleaned off the bottom of boat with degreaser and the fuel tank while i was in there. patched the small hole with 2 part epoxy inside and out.
pics of floor coming out. new foam in and coated wood going in.
putting carpet on the x cooler. was a cooler/battery cover box. cooler was plastic insert. ice lasted about an hr on a hot day. removed insert and cut the alum box back to add some foot room.
