CurrentObsession
- Aug 26, 2011
- 235
1999 Mercruiser 454 mag MPI with typical oil filter mounted upside down up high on the forward port side.
Went to change the oil and filter yesterday and was greeted with a big mess as most of the contents of the filter was not pre-drained as usual. My previous experience with these systems is that 90% plus drains back down to the sump after the engine is turned off. It was a good 15 minutes since I had turned the motor off. I did loosen it slightly to break any vacuum that may have built up. Seems like the return hole down in the bowl of the cast iron assembly was not draining or draining incredibly slowly.
Should I be concerned? Should I try to poke something through? I don't see any obvious obstruction at the top.
