Cavalier turn signals
fireman57
Sons '91 Cavalier's turn signal quit working. Usually no problem right? Checked and made sure that all his bulbs were okay, changed the yellow flasher fuse under the dash, and even replaced the turn signal mechanism itself. Sucker still doesn't work and I can't figure out why. Anyone have any suggestions? The four way flashers work.
Reel Poor
Re: Cavalier turn signals
Be sure you changed the right flasher. The emergency and turn signals use different flashers. The emergency signal flasher is located under dash panel left side of steering column. The turn signal flasher is located under dash panel right side of steering column. Also ck voltage to flasher.
fireman57
The only flasher that we have found is on the far right side of the steering column. There is a small white square diode next to it that has nothing to do with the turn signal. Is there another flasher on the passenger side? Haven't dropped that panel yet as have been working on the ouboard.
Bob_VT
Do the 4 way flashers work? I will almost bet you lost a ground somewhere maybe in the steering column.
Reel Poor
here is a wiring diagram. I hope it helps.<br /><br />
20/20
8 times out of 10 when the lights don't work it has something to do with a ground wire{if it's not the bulb}. This vehichle is old enough to have this problem{I've even seen new ones that have bad grounds}
fireman57
Yes 4 ways work. Reel Poor thanks for the diagram. Guess I'll go chasin wires. Thanks again guys.
