npd4432
- Apr 18, 2006
- 468
I have a 1983 Sportcraft Sportsman boat with a 1983 Evinrude 75 HP motor model # E75TRLCTE. The prop is a 13 3/4 x 13 Solas aluminum prop. The motor does have power tilt and trim. When turning at WOT the prop ventilates until you straighten it out again. This only occurres when turning at a moderate to hard turn. The trim is full down and the motor is in its lowest position on the transom. The boat also has smart tabs. Any help to alleviate this problem would be appricated.
