Woodnaut
- Jul 4, 2007
- 634
Helping out a buddy with his pontoon boat. Here is the the technical stuff I know about:
Boat: 21' Starcraft Pontoon Boat ~1987
Engine: 1981 Johnson 90 HP (2 stroke) outboard
Prop: 3 Blade Alum
Diameter unknown, Pitch 17" (I think), no cup
Tachometer presently inoperative (on the list of stuff to fix)
Symptoms: The boat previously had a 70 Hp 1987 Johnson with 3 blade SST prop (Dia and Pitch unknown). The boat and engine ran great on smooth water at all speeds including WOT. But with heaver loads, and particularly in choppy waters, the engine would rev up indicating that either cavitation or ventillation was occurring. The 70 HP suffered powerhead damage and was recently replaced with a 1981 90 HP Johnson with a 3 blade aluminum prop.
This 90 HP setup is exhibiting the same symptoms except the cavitation/ventillation is occurring even on smooth water when the engine is run at higher RPM.
It seems to me that on a conventional boat, the water coming from under the boat hits the outboard's lower unit at approximately the same place regardless of sea conditions. On a pontoon boat, however, it seems that in choppy seas the "water level" on the lower unit would vary with each passing wave. If this is the case then I could see where ventillation might occur.
I'm also guessing that if the prop pitch is too low, or if it needs some cup added to it, then perhaps cavitation is occurring. Maybe even a spun hub would exhibit some of these symptoms...
Sorry I don't have more particulars on the prop and WOT RPM. Any thoughs and suggestions are welcomed.
Prop: 3 Blade Alum
