I have just finished rebuilding a 55 CD12 and after firing it up in a tank it seems to skip when taking it up to full throttle. The parts replaced were the rings, total ignition and gapped to 020, carb rebuild with new float and adjusted 1.5 turns slow needle and 1 turn high needle, lower unit sealed and impeller replacement. I have also rebuilt the pressure tank that holds pressure fine. Any thoughts?
