Hi? I have a 95 120 force with a cdi rectifier and stator. My rectifier has two yellow wires and one gray wire. Which of this wire is primarly for charging or is the alternator wire.
I am working on installing a battery isolaton on my boat. One battery for starting the boat only and second for accessories. My isolator instruction says to connect the wires that comes from the isolator "a" terminal to the yellow and gray wire that comes from the rectifier but my cdi rectifier has two yellow wires and a gray wire.
I want to know where and which wire to tap/splies into and connect my isolator a terminal wire to charge my second battery and not using any power what so ever from my main starting battery.
I tried to connect the wire that comes from the isolator a terminal to the location on the engine where the main positive wire comes from. It charges my battery but my accessories are feeding on both battery. How do i found out. I took out/off the positive cable from my second battery and my accessories are still on and when i took off the power wire from the main starting battery they went off.
This tells me that because the wires that comes from the isolator a terminal is having a direct contact with the boat main positive cable at the engine terminal where the main positive wire came from .
So i think the battery isolator instruction is saying to avoid that, tap directly to the yellow and gray wire that comes from the rectifier before it get to the terminal where the main positive engine wire originate from and goes to the main starting battery.
Thanks for all your help. God bless.
