atomnewton
- Jun 27, 2007
- 2
I have a 1985 DT65. I tried to change the ignition switch from a key switch to a push button, and along the way I think I damaged the CDI unit. The engine will crank but not run. I noticed there is no spark on the plugs when I crank the engine. I tested both wires running into the CDI unit while cranking and they are both bringing in current. The one white wire that heads out of the CDI to the coil then spark plugs doesn't have a current running through it when I crank the engine. Since the CDI is getting current but not putting out current does that mean it's broken or is there still something else I'm missing? Is there a way to test the CDI before I go and buy another one? There aren't any shops in my area that will work on a Suzuki, so I'll probably have to figure this out myself.
Thanks for any help!
Joe
Joe
