skydiveD30571
- Feb 13, 2012
- 1,042
I've been having a tough time getting my boat centered on the bow roller. It seems to always want to go to the port side. It's a 2007 Seaswirl 210 bowrider on a matching EZ-Loader trailer. It is nice and centered on the keel. The trailer has 4 bunks, (beginning at the keel) the two outside bunks are short and the two inside bunks run further forward. As you can tell in the pictures, the inside bunks have a little gap but are centered. All trailer components are from the factory and have not been modified.
You can tell from the pictures that the bow roller from the factory is pretty small compared to some others I've seen. Also, a lot of boats have a pretty definitive "V" shape to the hull up at the front which I imagine helps them center on the roller. The area around the bow eye on my boat is very flat so it doesn't work itself into center very well. As you can tell, this wears on the winch strap until it started tearing last week. I'm going to order a new strap, but before I did that I wanted to see if a different roller would help. Or maybe technique, lining it up by hand as I crank the winch. Thanks for the input.
