I'm currently restoring a 1989 Four Winns 315 Vista and contemplating the installation of a central vacuum unit with two inlets; one in the **** pit and the other in the cabin. Are there "code" requirements for the installation of such?
My concern stems from a conversation I had with a web store tech support person who couldn't tell me if the units they promote as "RV/Marine" are ignition protected or not or, shouldn't be installed anywhere near the engine compartment. Even though these units generally use PVC piping a leak/faulty joint could be a fatal problem. When I was taking classes for my captain's license the Coast Guard told a story of how a man accidentally killed himself. He was using a shop vac to clean out his bilge; there was a small fuel leak in the engine compartment that expelled fumes. The fumes went up the hose and the shop vac blew up like a bomb once the fumes hit the motor.
I'd welcome any input or guidance as to how others have approached this installation.
Thanks,
Frank
Thanks,
Frank
