ceshen
ceshenb
i have an 1989 force and the question i have is does the water tube mount to something in the leg and if so how do you mount it?
Thanks
Stachi
Re: ceshen
How about telling us what hp it is ? Welcome to iboats. The more info you give us , the better we can help you. You might try asking, with all the pertinent data, in the Force Outboard section.
woops , looks like it has already been moved over....
jerryjerry05
Re: ceshen
Guessing that you have a 125 or 85 HP.
The water tube is mounted on the top of the motor leg.The pics are on the gear housing.Iboats diagrams,parts #1#2#3#4#5 It's a B(*&^% to remove and install.
If you have it out it takes a bunch to replace it.J
ceshenb
Re: ceshen
Thanks I boat is an awesome program. Its an 85 hp. Its my first boat and have put a lot of time new parts and money on getting the motor to run correctly and go to change the impeller an i noticed the tube was loose and figured it wasnt right. I clymer force manual and was real careful on removing the tube from lower unit. Where can i find instructions on fixing this?
jerryjerry05
Re: ceshen
Profile??You might be close to someone who can help.
If it's loose leave it alone.If it came out then I believe the powerhead needs to come off.J
ceshenb
Re: ceshen
lol sob no i can pull it out an move it around. So the power head must come off then well the manual tells me how to do that. i also pulled the leg cover and found a black rubber gromet in the water port looks like it will fit on the tube
ceshenb
Re: ceshen
I live in pittsburgh pa thanks so much for your help cause now i know what i have to do...
